Hi Ed,
This sounds like something discussed in these tech-talk messages:
http://www.aps.anl.gov/epics/tech-talk/2008/msg00356.php
http://www.aps.anl.gov/epics/tech-talk/2008/msg00357.php
We had the font init problem when upgrading to RHEL6 and applied the solution from msg00357.
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Ed Villasenor
> Sent: Tuesday, December 13, 2011 9:30 PM
> To: John William Sinclair; [email protected]
> Subject: Re: EDM Installation Error
> Dear John,
> I was able to compile edm by changing the const char to char.
> Unfortunately when I try to start EDM, "Font init failed - abort" error
> is displayed. Do you know if this error is related to the remFileOpen.cc
> file that I altered.
> Regards,
> Ed
> Ed Villasenor <[email protected]>
> On Mon, 05 Dec 2011 09:33:26 -0500
> John William Sinclair <[email protected]> wrote:
> > Ed,
> > The problem is that some versions of g++ require a cast of the form
> > (const char *)
> > and others require (char *). Try editing the file and changing the
> > offending lines from
> > one of those forms to the other.
> > John Sinclair
> > Ed Villasenor wrote:
> > > Dear All,
> > > I'm currently installing EDM on a CentOS 6 laptop and came accross the
> > > same problem described here:
> > > hxxp://www.aps.anl.gov/epics/tech-talk/2010/msg00157.php
> > > and hxxp://www.aps.anl.gov/epics/tech-talk/2009/msg01681.php
> > > Has the solution for this problem been found?
> > > Additional Info
> > > - EPICS Base: 3-14-11
> > > - EDM: 1-11-2i
> > > - installed
> > > epics base
> > > medm
> > > libpng-1 . 2 . 6rc1-config . tar . gz
> > > libungif-4 . 1 . 3 . tar . gz
> > > giflib-4 . 1 . 3 . tar . gz
> > > zlib-1 . 2 . 5 . tar . gz
> > > openmotif-2 . 3 . 3-1 . el4.5.i386.rpm
> > > openmotif-devel-2 . 3 . 3-1 . el4.5.i386.rpm
> > > I have previously installed EDM on a CentOS 5 Workstation without having
> > > this problem.
> > > Kind Regards,
- EDM Installation Error Ed Villasenor
- Re: EDM Installation Error Ed Villasenor
Re: Tektronix 3000/5000 oscilloscopes Pavel Masloff
Re: synApps 5.6 release J. Lewis Muir
<2011>
2025
problem using shell command in EDM Maurizio Montis
<2011>
2025
