1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: CSS Export Waveform data
To: John Dobbins <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 16 Dec 2011 10:55:57 -0500
... AND you need to select "Decimal" or "Exponential" notation.
If you use the "Default" notation, it's truncated after 21 values.
-Kay
On 12/16/11 10:31 , "Kasemir, Kay" <[email protected]> wrote:
>Hello:
>Should be fixed in August 2011.
>The code that handles this is in
>org.csstudio.trends.databrowser2.export.ValueFormatter.java
>Thanks,
>Kay
>On 12/16/11 09:54 , "John Dobbins" <[email protected]> wrote:
>>Apologies if this is addressed elsewhere and I missed it.
>>I used CSS to export Archive data for a waveform record and found that
>>the export data contained the first 21 values of the waveform followed
>>by '...'
>>Is this behavior alterable?
>>John Dobbins
>>Cornell Laboratory for Accelerator-based Sciences and Education
>>Cornell University
>>Ithaca, NY
Re: CSS Export Waveform data Kasemir, Kay
Prev: RE: Sequencer build errors on Windows Mark Rivers
Next: RE: CSS Export Waveform data John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: CSS Export Waveform data Kasemir, Kay
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
