1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: application build error with new sequence program
To: "S. Stein" <[email protected]>, <[email protected]>
Date: Wed, 21 Dec 2011 16:30:29 -0600
Is your sequencer calling some functions from another library?  How do the link commands that EPICS is generating compare for your sequencer and the example sequencer?
Sent: Wed 12/21/2011 4:26 PM
To: [email protected]
Subject: application build error with new sequence program
Greetings,
  I have a minGW build of epics 3.14.12.1 - and using an older version of the sequencer (I haven't been able to try Benjamin's fix for the newest release yet). I have built and run the example sequence, and now am replacing that one with my own. When I do a 'make' I get the following error:
g++ -o sncProgram.exe  -LC:\Users\Josh\base-3.14.12.1\lib\win32-x86-mingw -LC:\Users\Josh\seq-2.
0.14\lib\win32-x86-mingw       -m32               scaStartup.o    -lseq -lpv -lcas -lgdd -lasHos
t -ldbStaticHost -lregistryIoc -lca -lCom
c:/mingw/bin/../lib/gcc/mingw32/4.6.1/../../../libmingw32.a(main.o): In function `main':
C:\MinGW\msys\1.0\src\mingwrt/../mingw/main.c:73: undefined reference to `WinMain@16'
collect2: ld returned 1 exit status
make[2]: *** [sncProgram.exe] Error 1
I verified that the application will build fine when I point the Makefile back to the example sequence program, so it seems isolated to my new sequence; however I can see nothing peculiar in that .stt file. Has anyone seen this creep up before and can offer the simple "just add this" solution?
--Josh
Re: application build error with new sequence program S. Stein
Prev: application build error with new sequence program S. Stein
Next: Re: application build error with new sequence program S. Stein
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
