1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem of "The CA server's beacon address list was empty after initialization"
To: '王林' <[email protected]>, <[email protected]>
Date: Tue, 3 Jan 2012 09:17:26 -0700
Hello Lin Wang,
At least some of the patches accommodating vxWorks 6.x can be seen at this URL.
http://bazaar.launchpad.net/~epics-core/epics-base/3.14/revision/12090
In particular I suspect that some patches to src/libCom/osi/os/vxWorks/osdSock.h, documented in the above URL, are resolving this particular issue that you are encountering when using the earlier 3.14.11 release with vxWorks 6.x.
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
From: [email protected] [mailto:[email protected]] On Behalf Of ??
Sent: Thursday, December 29, 2011 6:19 AM
To: [email protected]
Subject: Problem of "The CA server's beacon address list was empty after initialization"
Hello All,
When I install EPICS 3.14.11 on RHEL4.8 for VxWorks6.8/vxWorks-ppc604_long, then create an example app, and load it to MVME5100, it will display "The CA server's beacon address list was empty after initialization?" like this:
-> </home/wanglin/vx6_8_ep11App/iocBoot/iocexample/st.cmd
## Example vxWorks startup file
cd "/home/wanglin/vx6_8_ep11App"
value = 0 = 0x0
ld < bin/vxWorks-ppc604_long/example.munch
value = 40806864 = 0x26ea9d0
dbLoadDatabase "dbd/example.dbd"
value = 0 = 0x0
example_registerRecordDeviceDriver pdbbase
value = 0 = 0x0
dbLoadTemplate "db/user.substitutions"
value = 0 = 0x0
dbLoadRecords "db/dbSubExample.db", "user=wanglin"
value = 0 = 0x0
iocInit
Starting iocInit
## EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$
## EPICS Base built Dec 29 2011
value = 0 = 0x0
-> The CA server's beacon address list was empty after initialization?
I do not change any environment variables, and this problem do not happen to me for EPICS 3.14.12.1. It seems that the Bug #541358 mentioned before was fixed on EPICS 3.14.11, and the file iocinf.cpp and online_notify.c of 3.14.11 and 3.14.12.1 are the same.
So, what probably results in this problem? And how can I solve it?
Lin Wang
Prev: EPICS Collaboration Meeting Spring 2012 [Happy New Year to All] Ernest L. Williams Jr.
Next: RE: The crash of Matlab using LabCA Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
