Your readline library may need ncurses.
Try commenting out the "COMMANDLINE_LIBRARY=READLINE" line
and uncommenting the "COMMANDLINE_LIBRARY=READLINE_NCURSES" line
in base/configure/CONFIG_SITE.Common.linux-x86.
Janet
----- Original Message -----
To: "Eric Norum" <[email protected]>, "Till Straumann" <[email protected]>
Cc: [email protected]
Sent: Wednesday, January 11, 2012 9:58:27 PM
Subject: Re: RTEMS-MVME2300
Hello
I have come to the step of installing EPICS for rtems-mvme2307. However the make is going unsuccessful.
I am attaching the output of running make. I need guidance to proceed.
Regards
Zia
On Wed, Jan 4, 2012 at 11:53 AM, Eric Norum < [email protected] > wrote:
The difference is that -DMY_DO_BOOTP=rtems_bsdnet_do_bootp tells the BSP to get the board network configuration from a BOOTP/DHCP server while -DMY_DO_BOOTP=NULL tells the BSP to get the network configuration from the NVRAM.
On Jan 3, 2012, at 7:46 PM, Michael Davidsaver wrote:
> Hello Qazi,
> There is support in RTEMS for the mvme2307 which is used with epics at
> NSLS. The epics build config used (see attached) is very similar to
> that of the mvme2100.
> The only real difference that I can see from the 2100 config is
>> #ARCH_DEP_CFLAGS += -DMY_DO_BOOTP=NULL
>> ARCH_DEP_CFLAGS += -DMY_DO_BOOTP=rtems_bsdnet_do_bootp
> I don't know what necessitated this though.
> I hope that this is helpful.
> Michael
Eric Norum
[email protected]
- Re: RTEMS-MVME2300 Eric Norum
- Re: RTEMS-MVME2300 Qazi Zia-ul-Haque
RE: Strategies for working with fast-changing large arrays michael.abbott
<2012>
<2012>
