Hi, It does, but they may be presented in a different, less user friendly way, I've included screenshots of the prosilica GC series screens. The aravis library exposes the genicam data of the camera, and my wrapper just provides a parameter for each element in this data. I use a python script at build time to parse the genicam xml and create a suitable database and edm screen with all the relevant parameters. This has the advantage that it can support new cameras very easily, but you lose any code that the manufacturer put in their SDK because they couldn't implement it in the genicam layer. E.g. Changing the sync outputs requires you to select the sync output you would like to change before changing its level, polarity, etc. As Michael said, it is missing code to set a camera IP address, although I have some test code that allows connection by IP address. Thanks, Tom Cobb -- +44 (0)1235 778582 > -----Original Message----- > From: Mark Rivers [mailto:[email protected]] > Sent: 12 January 2012 18:06 > To: 'Davidsaver, Michael'; [email protected]; Cobb, Tom > (DLSLtd,RAL,DIA) > Subject: **Possible spam**RE: Does areaDetector Prosilica driver > support Manta-series camera ? > > Hi Michael and Tom, > > Does the aravis driver provide support for all the things in the > prosilicaMore screen (attached), i.e. trigger, sync in/out, stream > bytes per second, communications statistics, etc.? > > Mark > > > -----Original Message----- > From: [email protected] [mailto:tech-talk- > [email protected]] On Behalf Of Davidsaver, Michael > Sent: Thursday, January 12, 2012 10:49 AM > To: [email protected] > Subject: RE: Does areaDetector Prosilica driver support Manta-series > camera ? > > In case anyone is interested. I've been using the aravis based driver > with some prosilica GC cameras at NSLSII for several months. It worked > for me right out of the box. Also, the aravis library comes with a > nice command line tool which was useful for testing. > > The only features lacking in aravis are connection by IP address (as > opposed to broadcast), and support for the (AVT specific) protocol > extension to set the camera's IP address. > > Regards, > Michael > > > > -----Original Message----- > > From: [email protected] [mailto:tech-talk- > > [email protected]] On Behalf Of [email protected] > > Sent: Thursday, January 12, 2012 8:38 AM > > To: [email protected]; [email protected]; tech- > > [email protected] > > Subject: RE: Does areaDetector Prosilica driver support Manta-series > > camera ? > > > > It is also supported in the generic GigE driver (aravis): > > http://controls.diamond.ac.uk/downloads/support/aravisGigE > > > > Tom > > > > > -----Original Message----- > > > From: [email protected] [mailto:tech-talk- > > > [email protected]] On Behalf Of Mark Rivers > > > Sent: 12 January 2012 13:01 > > > To: Chen, Hsin-Wei; [email protected] > > > Subject: RE: Does areaDetector Prosilica driver support Manta- > series > > > camera ? > > > > > > Yes, it should work. The Manta uses the same vendor library as the > > > other Prosilica (AVT) GigE cameras. > > > > > > Mark > > > > > > ________________________________ > > > From: [email protected] [[email protected]] > > on > > > behalf of Chen, Hsin-Wei [[email protected]] > > > Sent: Wednesday, January 11, 2012 9:17 PM > > > To: [email protected] > > > Subject: Does areaDetector Prosilica driver support Manta-series > > > camera ? > > > > > > Can I use prosilica driver to control manta camera? > > > > > > -- > > > National Synchrotron Radiation Research Center Hsin-Wei Chen > > > Email: [email protected]<mailto:[email protected]> > > > TEL: 886-3-5780281-7220 > > > FAX: 886-3-5783813 > > > Address: 101 Hsin-Ann Road, Hsinchu 30076, Taiwan > > > ?家同步?射研究中心 > > > ?鑫? > > > 30076新竹市新安路101? > > > ?一??: 05601093 > > > > > > Attachment:
prosilica_GC.png Attachment:
ANJ, 18 Nov 2013 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
