1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Rec Proc Monitor for mbbi ZRST
To: [email protected]
Cc: "Peters, Charles C." <[email protected]>
Date: Fri, 13 Jan 2012 18:03:49 -0600
Hi Charles,
On 2012-01-13 Peters, Charles C. wrote:
> I want the mbbi st to be monitored for a change.  I can modify the .ZRST at
> runtime, but it is not monitored so I am unable to really change it.
> Is it possible to modify my mbbi to monitor the ST fields?
How are you changing the ZRST field?  If it's from a device support's
read_mbbi() routine then after changing the field string it should also call
    db_post_events(prec, &prec->zrst, DBE_VALUE | DBE_LOG);
to post value and archive monitors on the ZRST field and
    db_post_events(prec, &prec->val, DBE_PROPERTY);
to post a property monitor event on the VAL field.  However for many CA
clients this will not result in them updating their list of choice strings for
the VAL field because the DBE_PROPERTY monitor event was new in 3.14.11 and
most CA client programs don't use it yet.
Note that you should never try to do this from an interrupt service routine,
db_post_events() should only be called from task level with the record locked.
If you're using CA to change the ZRST field then the IOC should already be
posting value and archive monitors on ZRST when you put the new value, but if
your CA clients don't have a DBE_PROPERTY monitor on the VAL field they won't
know anything about the string name for that state changing.
You have just pointed me to a bug though; the record should be posting value
and archive monitors on the VAL field at the same time as the DBE_PROPERTY
event if the VAL field's contents currently match the xxST field that was
changed.  I'll fix that in the next release, and if you add my code above you
should probably do the same thing, like this instead of my second line:
    int event = DBE_PROPERTY;
    if (prec->val == 0) event |= (DBE_VALUE | DBE_LOG);
    db_post_events(prec, &prec->val, event);
HTH,
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
DBE_PROPERTY support in R3.14.11, gateway, CSS, MBBI/MBBO Re: Rec Proc Monitor for mbbi ZRST Kasemir, Kay
Rec Proc Monitor for mbbi ZRST Peters, Charles C.
Prev: Rec Proc Monitor for mbbi ZRST Peters, Charles C.
Next: problem with 64 bit build of EDM v1-12-68 John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: DBE_PROPERTY support in R3.14.11, gateway, CSS, MBBI/MBBO Re: Rec Proc Monitor for mbbi ZRST Kasemir, Kay
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
