John,
You need to do "make clean uninstall" to get rid of those files.
From: [email protected] [[email protected]] on behalf of John Dobbins [[email protected]]
Sent: Sunday, January 15, 2012 9:36 AM
To: EPICS Tech-Talk
Subject: RE: problem with 64 bit build of EDM v1-12-68
This is resolved.
After noticing that files EDM put into
extensions/bin
extensions/inculde
extensions/lib
were not removed by "make clean" (should they be?)
I removed them manually so as to truly start from scratch.
Then the build proceeded normally.
The error originally reported (below) was after several build attempts.
John Dobbins
Sent: Friday, January 13, 2012 10:56 PM
To: EPICS Tech-Talk
Subject: problem with 64 bit build of EDM v1-12-68
All,
I am attempting to build EDM on 64 bit linux for the first time.
configuration:
gcc 4.4.5 [Scientific Linux release 6.1 (Carbon)]
epics R3.14.12.2
EDM 1-12-68
calc_pv_factory.cc fails, see below.
Any advice?
John Dobbins
Cornell University
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux
-D_REENTRANT -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -m64
-fPIC -MMD -I. -I../O.Common -I. -I..
-I../../../../include/edm/os/Linux -I../../../../include/edm
-I/nfs/erl/erp/epics/R3.14.12/support/base-3.14.12.2/include/os/Linux
-I/nfs/erl/erp/epics/R3.14.12/support/base-3.14.12.2/../../extensions/include
-I../../util -I../../lib -I/usr/include -I/usr/include/X11
../calc_pv_factory.cc
../calc_pv_factory.cc: In function \u2018bool equals(const
HashedCalcPvList*, const HashedCalcPvList*)\u2019:
../calc_pv_factory.cc:501: error: cast from
\u2018CALC_ProcessVariable*\u2019 to \u2018unsigned int\u2019 loses
precision
precision
../calc_pv_factory.cc:504: error: cast from
precision
precision
../calc_pv_factory.cc: At global scope:
../calc_pv_factory.cc:613: warning: invalid access to non-static data
member \u2018HashedExpression::node\u2019 of NULL object
../calc_pv_factory.cc:613: warning: (perhaps the \u2018offsetof\u2019
macro was used incorrectly)
../calc_pv_factory.cc:617: warning: invalid access to non-static data
member \u2018HashedCalcPvList::node\u2019 of NULL object
../calc_pv_factory.cc:617: warning: (perhaps the \u2018offsetof\u2019
../calc_pv_factory.cc: In member function \u2018void
CALC_ProcessVariable::completeCreation(HashedExpression*)\u2019:
../calc_pv_factory.cc:1289: warning: comparison between signed and
unsigned integer expressions
make[3]: *** [calc_pv_factory.o] Error 1
make[3]: Leaving directory
`/nfs/erl/erp/epics/R3.14.12/extensions/src/edm/calcPv/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory
`/nfs/erl/erp/epics/R3.14.12/extensions/src/edm/calcPv'
make[1]: *** [calcPv.install] Error 2
make[1]: Leaving directory `/nfs/erl/erp/epics/R3.14.12/extensions/src/edm'
make: *** [edm.install] Error 2
- RE: problem with 64 bit build of EDM v1-12-68 John Dobbins
- problem with 64 bit build of EDM v1-12-68 John Dobbins
<2012>
2025
<2012>
2025
