On 1/23/2012 9:03 AM, Phillip Sorensen wrote:
Hello,
I see references to support for Galil motor drivers, but I have not
found links to any code. Does anyone has device support (specifically
for the motor record) for the Galil DMC-2183 or similar unit.
Phil Sorensen
Phil,
I believe the similar unit I have is the DMC-2140 (maybe, I'd have
to check). I didn't have a reason to tie the controls to a motor record
because all the position handling is controlled within the Galil code.
I just set some parameters as needed and execute functions from the
programmed firmware.
Wesley
- Motor record support for Galil DMC-2183 Phillip Sorensen
RE: Motor record support for Galil DMC-2183 Mark Rivers
<2012>
2025
<2012>
2025
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
