1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: odd behavior of 'dbpf' on windows softioc
To: "'Josh Stein'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 25 Jan 2012 23:29:37 +0000
Hi Josh,
I have seen this problem, at least in the past.  But right now on my win32-x86 IOC I do not have the problem with the bo records I have tested:
epics> dbpf 13ANDOR1:cam1:AndorCooler.VAL 0
DBR_STRING:          "Off"
epics> dbpf 13ANDOR1:cam1:AndorCooler.VAL 1
DBR_STRING:          "On"
epics> dbpf 13ANDOR1:cam1:AndorCooler.VAL Off
DBR_STRING:          "Off"
epics> dbpf 13ANDOR1:cam1:AndorCooler.VAL On
DBR_STRING:          "On"
It works either with the integer values or the enum strings.
This is with EPICS 3.14.12.2.
From: [email protected] [mailto:[email protected]] On Behalf Of Josh Stein
Sent: Wednesday, January 25, 2012 2:44 PM
To: [email protected]
Subject: odd behavior of 'dbpf' on windows softioc
In the past, I routinely did reads and writes into records on the ioc console; one common action is to 'flip a bit' on a BO record by writing a 1 or 0.
For example,
console>dbpf "testborec","1"
or even:
console>dbpf "testborec.VAL","1"
This does not seem to function properly on my 3.14.11 Windows softIOC:
epics>dbpf "wst:v13C","1"
Illegal choice PV: wst:v13C  1
filename="../dbTest.c" line number=333
Illegal choice - dbPutField error
It appears that I can only put an enumerated value into the value field; so to correct the above example:
epics>dbpf "wst:v13C","Open"
DBR_STRING:        "Open"
seems to work fine.
Is this a feature, flaw, or user error on my part?
odd behavior of 'dbpf' on windows softioc Josh Stein
Prev: odd behavior of 'dbpf' on windows softioc Josh Stein
Next: RE: Motor record support for Galil DMC-2183 Mark Clift
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: odd behavior of 'dbpf' on windows softioc Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
