Am Freitag, 27. Januar 2012, 22:46:42 schrieb Matthieu Bec:
> I am looking for a framework to develop state machines, à la SEQ/SNL but
> ... not targeted to epics or channel access.
Which system are you interested in, instead of EPICS/CA?
> The PV API - still present in seq-2.1.4? - seems to go in the right
> direction, but I recall a discussion in 2010 stating it might eventually
> go away.
Does your system fit the PV API framework? It should at least support
subscriptions, i.e. notification messages when a value changes. How are a
variable's alarm status and severity encoded and is this compatible to the way
the PV API defines them?
I may be persuaded to keep the PV layer if it turns out it is of any practical
use. I just don't like to maintain code that nobody uses and thus merely adds
overhead (runtime and maintenance costs). BTW, the sequencer uses only a
subset of the existing API, which I can identify to you, if you are
interested. In any case it would make sense to reduce the API to what the
sequencer actually needs.
Cheers
Ben
- Last chance to save the sequencer's pv layer ? Matthieu Bec
Re: Last chance to save the sequencer's pv layer ? Peter Young
edm1-12-69 Szalata, Zenon M.
<2012>
2025
<2012>
2025
