Subject: EDM dosn't handle file system links
To: EPICS tech-talk <[email protected]>
Date: Mon, 30 Jan 2012 15:25:12 +0100
Hello TechTalk,
can someone verify that EDM dosn't work very well with hard or
symbolic-links  under linux?
What I did:
created a file and reused it in different projects via link. One day I
edited not the source file rather the link and saved it with "save",
thus breaking the link.
original state:
~/file_lnk.edl ---> /lib/file.edl
1st save:
~/file_link.edl
~/file_lnk.edl~ ---> /lib/file.edl
2nd save:
~/file_link.edl
~/file_lnk.edl~
it seems to happen with softlinks as well as with symlinks. With
symlinks it's easier to investigate. Using hardlinks it helps using
"stat /lib/file.edl" to see if the file has links and "find / -samefile
/lib/file.edl" to see where are these pointing to.
thanks in advance
Fabian
PS works as well "find / -inum ?????"
Re: EDM dosn't handle file system links Andrew Johnson
Prev: edm1-12-69 Szalata, Zenon M.
Next: Re: EDM dosn't handle file system links Andrew Johnson
Prev: RE: edm1-12-69 Szalata, Zenon M.
