Subject: RE: mvme6100 HW issues?
To: Vesna Samardzic-Boban <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 1 Feb 2012 08:38:54 -0800
Hi Vesna,
At SSRL/SPEAR, we had a high failure rate for our MVME6100 boards until we pulled all EMI stripes off our Wiener VME crates.  The boards were repaired by the manufacturer.
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Vesna Samardzic-Boban
> Sent: Tuesday, January 31, 2012 10:47 PM
> To: [email protected]
> Subject: mvme6100 HW issues?
> Hi,
> Has anyone experienced HW issues with MVME6100 board (or any other MVME board)?
> Recently we bought our first Motorola/Emerson MVME6100 board.
> It worked fine for about a couple of months but then it would start to show errors and stop
> working (unresponsive).
> As nothing was changed in the HW setup (only that board in the crate, the crate open, the
> fan ok, etc.), and the errors caught on the screen looked like given below, I believe it could
> be a HW fault.
> Some of the errors caught on the screen:
> MVME6100>
> isr: CPU Bus Parity Error
> isr: Reg0x78 = 000001f0, Address = 002d6ab8
> isr: Data High:Low = 00000000:00000000
> isr: Parity = df, Cause = 30000040
> After the screen freezes, it is not possible to enter anything from the keyboard.
> It happens regardless of the way i boot i.e. for both MOTLoad FW (S4 = off on on off) or
> vxWorks (S4 = off off off off).
> I noticed the heatsink on the board is loose and possibly not mounted properly (also would
> get very hot) - so I just sent it back to the supplier/manufacturer.
> Has anyone experienced similar problems with mvme6100 or any other mvme board?
> Regards, Vesna
> Vesna Samardzic-Boban | Senior Controls Engineer | Australian Synchrotron
> p: (03) 8540 4238 | f: (03) 8540 4200
> [email protected] | www.synchrotron.org.au
> 800 Blackburn Road, Clayton, Victoria 3168<br>This message and any attachments may
> contain proprietary or confidential information. If you are not the intended recipient or you
> received the message in error, you must not use, copy or distribute the message. Please
> notify the sender immediately and destroy the original message. Thank you.
5500 temp monitor Re: mvme6100 HW issues? Kasemir, Kay
RE: mvme6100 HW issues? Luchini, Kristi L.
mvme6100 HW issues? Vesna Samardzic-Boban
Prev: Re: DRVL, DRVH, HOPR, LOPR Gary Croke
Next: 5500 temp monitor Re: mvme6100 HW issues? Kasemir, Kay
Prev: RE: DRVL, DRVH, HOPR, LOPR Dalesio, Leo
