1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: How to get array of strings from waveform record?
To: <[email protected]>
Date: Tue, 14 Feb 2012 19:54:48 +0100
Am Dienstag, 14. Februar 2012, 19:34:20 schrieb Andrew Johnson:
> On 2012-02-14 Nerses Gevorgyan wrote:
> > I'm trying to put into waveform record an array of STRINGs.
> > As I understood from waveform code and manual the VAL field is
> > a void pointer which should be supplied by user.
> Sorry, if that's what the record reference manual says it's wrong.
> The prec->val field is never actually used inside the record source code.
> When you the access the VAL field of a waveform record through CA or a
> database link, the data is actually fetched from the prec->bptr field,
There is, BTW, no technical reason why VAL could not be used to hold the
pointer to the value buffer (instead of wasting another field for that) but,
presumably for historical reasons, that's not how it works.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführerin: Prof. Dr. Anke Rita Kaysser-Pyzalla
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
How to get array of strings from waveform record? Nerses Gevorgyan
Re: How to get array of strings from waveform record? Andrew Johnson
Prev: Re: How to get array of strings from waveform record? Andrew Johnson
Next: epics-arduino Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: How to get array of strings from waveform record? Nerses Gevorgyan
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
