Subject: Re: Connection to Siemens S7 PLC
To: Konrad Gajewski <[email protected]>
Cc: [email protected]
Date: Wed, 22 Feb 2012 09:19:58 -0800
At TRIUMF, we are using our own driver to talk to 400-series Siemens PLCs. It uses asyn, and was modeled after Mark Rivers' modbus PLC driver. The underlying communications protocol is the Siemens FETCH/WRITE protocol over TCP/IP.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
Konrad Gajewski wrote:
Hello everybody,
I'm new to EPICS and I am planning to control Siemens Simatic S7-200
PLC. I have looked in EPIC documentation and found at least two ways to
connect the PLC:
1. via MODBUS (Asyn) driver over the serial connection (using Siemens
MODBUS RTU library)
2. using S7plc driver via TCP/IP and a CP 243-1 Ethernet module.
The programming of the PLC is done using Step-7 Micro/WIN V4.0.
Unfortunately I can't open the example STEP 7 PLC project (for S7plc
driver) in Step-7 Micro/WIN.
Do you have any experience with such a configuration or maybe with
S7-1200? Are there any better options?
Konrad
AW: Connection to Siemens S7 PLC Rekow Jens
Connection to Siemens S7 PLC Konrad Gajewski
Prev: RE: Best pratices for compiling dbd files for asyn base device support Mark Rivers
Next: Re: CSS X-Y Graph Michael Davidsaver
Prev: RE: Connection to Siemens S7 PLC Mark Rivers
Next: AW: Connection to Siemens S7 PLC Rekow Jens
