I was thinking of a local solution for one process on one host, but I
will consider your global solution. I'm not sure I want every client
restarting their searches for disconnected channels.
Thanks.
Ralph Lange wrote:
Chris,
You need a beacon anomaly that your clients can see, so they rebroadcast
their unresolved names.
Quick-and-dirty solution:
The easiest way to create a beacon anomaly is to start up an IOC. Create
an empty soft IOC on a machine on the clients' network (the softIoc
executable from base is fine). Set up a cron job that starts the IOC,
waits a second, then kills it.
Whenever that cron job runs, all clients on the local network will try
to resolve their channels.
~Ralph
On 23.02.2012 14:18, Chris Slominski wrote:
I want to be able to force my EPICS channel access client to begin a
new search for currently disconnected channels.We have small short
term pc104 iocs come and go and sometimes they are not configured
correctly to broadcast when they have been booted up. A client
listening to the channels won't see a beacon anomaly and begin the
channel search sequence.
I can see a couple of ways to do this.
- Send a network beacon to the CA Repeater.
- Issue a search for some non-existent channel.
Please advise on what is a good way to do this. Example code or
references to EPICS source code are very welcome, as I am neither
familiar with EPICS base software, nor am I an experienced network
programmer. My client software uses EPICS 3.13.10.
Chris
- Re: Search for disconnected channels Andrew Johnson
- Re: Search for disconnected channels Ralph Lange
- Search for disconnected channels Chris Slominski
RE: QT-based tools: Expressions of interest requested david.hickin
RE: Best pratices for compiling dbd files for asyn base device support Abadie Lana
<2012>
2025
<2012>
2025
