Subject: Re: Epics-php module problem
To: Bertrand Alain <[email protected]>
Cc: [email protected], [email protected]
Date: Tue, 28 Feb 2012 11:57:00 -0500
In general, I've been satisfied with the performance of the php_epics module, though I only use it to display small numbers of PVs on a few specialized web pages.
I successfully compiled it on Redhat EL5 recently against PHP 5.3.10 using the following:
CC=gcc
export EPICS=/opt/epics/base-3-14-11
CFLAGS  =  -DUNAME="\"UNAME=$(UNAME)\"" \
   -DLOGINDATE="\"LOGINDATE=$(LOGINDATE)\"" -DUNIX  -I $(EPICS)/include \
   -I $(EPICS)/include/os/Linux  $(SERVER_CFLAGS) -I/usr/local/include -I. -I/opt/php/5.3.10/include/php/ \
   -I/opt/php/5.3.10/include/php/Zend -I/opt/php/5.3.10/include/php/TSRM \
   -I/opt/php/5.3.10/include/php/main -fpic -DCOMPILE_DL=1 -DPNG_SETJMP_NOT_SUPPORTED -DHAVE_PHP_STREAM
LDFLAGS = -static -shared -L/usr/lib -L $(EPICS)/lib/linux-x86 -lCom -lca  -lm -lc
Hope this helps,
-Theo
On 2/28/2012 11:13 AM, Bertrand Alain wrote:
We stopped working on this long time ago due to poor performances we got with PHP. We even actually stopped working with PHP so I must say I have no clue how you compile with PHP 5.
Sincerely,
Alain
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Tuesday, February 28, 2012 4:24 PM
To: [email protected]
Subject: Epics-php module problem
Is PHP parser/interpreter of adl files (MEDM) ready for use? If so, is it possible to share the source?
While compiling php_epics source it is showing error:
fatal error main/php_config.h : No such file
though I have mentioned the path of php-5 source in Gnumakefile as follows:
   -DLOGINDATE="\"LOGINDATE=$(LOGINDATE)\"" -DUNIX  -I $(EPICS)/base/include \
   -I $(EPICS)/base/include/os/Linux $(SERVER_CFLAGS) -I/usr/local/include -I. -I/home/php-5.x.x -I/home/php-5.x.x/Zend -fpic -DCOMPILE_DL=1 -DPNG_SETJMP_NOT_SUPPORTED -DHAVE_PHP_STREAM
Could you please point out the problem?
with regards,
Tanushyam Bhattacharjee
VECC,Kolkata
Epics-php module problem btanu
RE: Epics-php module problem Bertrand Alain
Prev: Re: QT-based tools: Expressions of interest requested Andrew Johnson
Next: RE: QT-based tools: Expressions of interest requested Chen, Xihui
Prev: RE: Epics-php module problem Bertrand Alain
Next: Re: Epics-php module problem btanu
