Subject: Re: Announce: sequencer release 2.1.5
To: <[email protected]>
Date: Thu, 1 Mar 2012 15:55:21 +0100
A bug report by Lewis Muir reached me right after this announcement. He also
provided analysis of the problem and a simple idea how to fix it. The
problem is documented on the web page and a fix contained in the latest
snapshot that I just uploaded. A new release 2.1.6 will be made soon.
BTW, the bug is old, it goes back to at least 2.0.12, an is probably present
in all versions starting with 2.0.0 (I didn't check, though).
Cheers
Ben
On Wednesday, February 29, 2012, Benjamin Franksen wrote:
> Hi All
> This is a bug fix release for the stable version 2.1 branch.
> As usual, documentation, release notes, download links, and install
> instructions can be found on the sequencer homepage:
>   http://tinyurl.com/epics-seq/
> User relevant changes since 2.1.4 are:
> * fixed two bugs in pvAssign:
>   - after an initially unassigned variable gets assigned using
>     pvAssign in safe mode, pvGet crashed the program
>   - when pvAssign was used to re-assign an already connected PV,
>     this was not correctly accounted for and a wrong warning
>     message was issued
> * extended the 'reassign' test to cover these issues
> * functions pvAssign and seq_connect (internal) leaked memory
>   when something fails; this has been fixed
> * several documentation fixes (thanks to Lewis Muir)
> * fixed a build problem with older base releases
>   (thanks to Bruce Hill)
> * internal renamings: SEQ_VERSION->SEQ_RELEASE, seqVersion->seq_release
> * know problems of published releases will from now on be
>   listed on an extra documentation page, with a link from the
>   release notes
> Cheers
> Ben
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
> Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv.
> Vorsitzende Dr. Beatrix Vierkorn-Rudolph Geschäftsführerin: Prof. Dr.
> Anke Rita Kaysser-Pyzalla
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführerin: Prof. Dr. Anke Rita Kaysser-Pyzalla
Postadresse:
D-14109 Berlin
Announce: sequencer release 2.1.5 Benjamin Franksen
Prev: Epics gateway writeNotify issue Provenzano Matteo
Next: BOY FAQ Chen, Xihui
Prev: Announce: sequencer release 2.1.5 Benjamin Franksen
Next: Epics gateway writeNotify issue Provenzano Matteo
