1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: CRC issues using Modbus/asyn on 64bit Linux
To: EPICS Tech Talk <[email protected]>
Date: Thu, 01 Mar 2012 18:29:30 +0100
I am reliably getting CRC errors on the device's answer when reading
more than two parameters (Modbus code 3) through serial RTU on RS-485
from a Wave P6100 temperature controller. The data itself looks good and
reasonable.
One or two word access (Modbus code 1 or 3) seems to work fine.
The IOC runs on 64bit Linux, using Mark Rivers' Modbus on ASYN driver.
(All from synApps 5.5)
Has anyone seen similar behaviour?
Does anyone successfully run Modbus/asyn on 64bit Linux? (To rule out 64
bit issues in the CRC checking part.)
Thanks for any help,
~Ralph
RE: CRC issues using Modbus/asyn on 64bit Linux Mark Rivers
Re: CRC issues using Modbus/asyn on 64bit Linux Martin L. Smith
Prev: BOY FAQ Chen, Xihui
Next: Re: BOY FAQ Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Epics gateway writeNotify issue Hill, Jeffrey O
Next: RE: CRC issues using Modbus/asyn on 64bit Linux Mark Rivers
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
