1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: BOY FAQ
To: "Sinclair, John William" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 2 Mar 2012 16:31:42 -0500
Hello John:
See online help (Menu Help, Help Contents),
look for CSS Applications, Display, BOY, Color and Font.
The help explains the format.
When you install the OPI examples, you also get example
color and font files in there,
then you set your preferences to use those.
Or download the Basic EPICS version which is preconfigured
to use the color and font files from the OPI examples.
Kay
On 3/2/12 16:06 , "Sinclair, John William" <[email protected]> wrote:
>I have downloaded the NSLS CSS product.
>After changing various config parameters, probe and data browser both
>work but BOY does not (pv does not resolve).
>One known problem: I have neither color.def nor font.def and the
>documentation
>complains about an invalid url when I click on the link references. Does
>someone
>have a link to documentation for these files? A simple working example
>would also be
>appreciated. Do I need these files or will the system supply defaults if
>they are missing?
>Thanks,
>John Sinclair
BOY FAQ John William Sinclair
Prev: BOY FAQ John William Sinclair
Next: BOY FAQ John William Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
