1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Channel Access
To: [email protected]
Date: Sun, 11 Mar 2012 14:01:41 +0200
Hi all
I am facing problems while after installing EPICS3.14.12.2. in a machine. The EPICS apparently installed successfully without reporting errors. An example application was also made and run using makeBaseApp.pl utility. However the problem is being faced while trying to access the CA variables using channel access. Path to the directory containing caget is added and caget is being called but returning failure in connecting to channel i.e. connectivity to CA variables is not being established.
I need your kind guidance for it.
With Best Regards
Zia
Control Engineer
Synchrotron-light for Experimental Sciences and Applications in the Middle East (SESAME)
P. O. Box 7, Allan 19252, Jordan
Phone: +962-5-3511348 Ext: 239
Cell:     +962-79-5295527
Res:      +962-5-3511463
Re: Channel Access Paul Sichta
Prev: RE: Here is a Message Szalata, Zenon M.
Next: ca_flush_io and threads michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: Channel Access Paul Sichta
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
