1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: MVME2434-1
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 16 Mar 2012 15:30:57 +0000
My answer was a little bit misleading (euphemism !)
The correct one is:
VxWorks version 5.3.1
KERNEL: WIND version 2.5
Thanks to Pierre Mattei to have pointed out this error.
-----Message d'origine-----
De : Bill Lavender [mailto:[email protected]]
Envoyé : mercredi 14 mars 2012 03:27
À : GOURNAY Jean-Francois; [email protected]
Objet : Re: MVME2434-1
I had been hoping for VxWorks 5 code, so VxWorks 2.5 is rather old.
However, I see that RTEMS has a BSP for the MVME2400 series.  Do you think that I would be better off with RTEMS and just forgetting about VxWorks?
Bill Lavender
On Tue, Mar 13, 2012 at 01:25:51PM +0000, GOURNAY  Jean-Francois wrote:
> Yes we use this CPU in several configuration for Acquisition systems for Magnet Protection system here at Saclay (W7X stellerator magnets  and R3B GSI magnet), at CERN (COMPASS solenoid) and Tokaï (T2K  J-PARC).
> The oldest configuration is more than 10 y.o. We never had any problem with this CPU. Quite different from the present situation where we had a lot of problem with our  present 5500 CPU choice.
> We are running an old configuration on them: VxWorks 2.5 buit in 2000
> and EPICS 3.13
> Jean-François
> De : [email protected]
> [mailto:[email protected]] De la part de Bill Lavender
> Envoyé : lundi 12 mars 2012 22:33 À : [email protected] Objet :
> MVME2434-1
> I have recently acquired an MVME2434-1 system controller board.  Is this something that anyone has ever used with EPICS?  Thanks.
> Bill Lavender
MVME2434-1 Bill Lavender
RE: MVME2434-1 GOURNAY Jean-Francois
Re: MVME2434-1 Bill Lavender
Prev: RE: Synchronising CA shut down Hill, Jeffrey O
Next: Re: ARM - EPICS performance evaluation Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: MVME2434-1 Bill Lavender
Next: [Operating System platforms] which one do you use? Pavel Masloff
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
