Subject: RE: Tech-talk Digest, Vol 6, Issue 121
Date: Sat, 31 Mar 2012 11:17:41 -0600
Eric,
At the CLS in the past we have used optical switch gear primarily to switch UCLP connections on the CANARIE CA*Net (our national research network).
The gear we were using for that project was from BigBagwith:  http://www.bigbangwidth.com/
Different application than the one you have, however these are true optical switches so what is carried in/out on the optical connection should not matter.
Elder
To: EPICS tech-talk <[email protected]>
Sent: Thursday, March 29, 2012 4:31 PM
Subject: Fiber Optic Switches
We are exploring the use of computer controlled fiber optic switches for switching between redundant signal sources.? Does anybody already use these things?? What brands do you recommend?? How fast do they switch?
All advice gratefully accepted.
Thanks
-Eric Bj.
URL: <http://www.aps.anl.gov/pipermail/tech-talk/attachments/20120330/35d8ac54/attachment.html>
Tech-talk mailing list [email protected] http://www.aps.anl.gov/mailman/listinfo/tech-talk
End of Tech-talk Digest, Vol 6, Issue 121
Prev: Re: Fiber Optic Switches Emmanuel Mayssat
Next: StripTool and History Paul E. Reimer
Prev: Re: Re: Problems in using VX2 motor controller sunjl
