On 4/4/12 09:57 , "Burkhard Kolb" <[email protected]> wrote: >Am 04.04.2012 um 15:49 schrieb Kasemir, Kay: >>If you zoom in far enough and your data source then automatically >> switches to raw data, you see that. >This would be cool - how far is enough? I have now about 5 samples in >time on the trend plot, >nevertheless the Inspect Samples shows me many thousand samples and does >not automatically switch >to raw data. There are two things happening here: 1) The data source determines how it provides the "optimized" data 2) The data browser merges that with what it already has in memory Attached are screenshots taken with an RDB (Oracle, stored procedure) as the data source, all using the "optimized" request. In the first snapshot, I look at a few days of data. The data source returns "interpolated" samples, specifically the min/max/average for about 800 bins across the requested time range. 800 can be adjusted in the preferences. The plot shows the average as a line, the min/max as a shaded outline. The sample inspector shows the interpolated values as "average [min ... max]". When I zoom in far enough, meaning: The data source determines that there are fewer than 800 samples in the time range, so I it can simply return the raw data, no need to optimize, we see the raw data: Only a line in the plot, no min/max outline, and the sample inspector also shows "Original". .. for the time range of the plot. The Data Browser still has the interpolated samples for the bigger time range in memory, like for the time before 11:10:04 in the snapshot. Somewhat like this: Interpolated data I I I I I Raw Data r r r r r r I I I I I I I That way, if you "zoom out" again, it can right away plot what it has, so you see _something_ while it requests updated data from the data server. This is for the RDB-based archive where we've invested the last couple of years of development. The channel archiver's data server doesn't understand min/max/avg samples. It returns a stream of initial/min/max/final samples where you can't tell which one is which, so no 'outline' is displayed. It may also not do such a good job when it comes to automatically falling back to 'original' data. I had to give up development of the Channel Archiver because the maintenance of its binary data and index files simply went out of hand for us at the SNS. We use a relational database for the data storage since 2009. Still, several sites have expressed interest in continuing to extend the Channel Archiver: 64bit data format, ... and asked for the sources to be opened up, so they've been on SourceForge for a couple of years. Maybe somebody wants to update the network data server's optimization code? The other thing that can happen is in the merging of newly received data with existing in-memory data: Again I'd like to keep the in-memory data, for example interpolated samples I I I I I I I I I I I I I I I I I I I I and then replace a subsection with newly received 'raw' data when you zoom in: I I I I I r r r r r I I I I I I I I I I But the interpolated samples also have interpolated time stamps. After you do that for a while, zooming in here and there, you can get this: r r r r I r r r r r I r r r I r r r r r You have a lot of raw data that replaced the interpolated data, but some interpolated samples remain because they're "in between" actual raw data. Thanks, -Kay Attachment:
opt.png Attachment:
ANJ, 18 Nov 2013 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
