1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: [db] simple command ?
To: Tim Mooney <[email protected]>
Date: Wed, 4 Apr 2012 20:43:29 +0400
Hi Tim, guys
You are right - I want the record to automatically switch its value back to 0 after somebody sets it to 1. Time doesn't really matter. Imagine a pneumatic valve. I have two records two control it: cmd:valve_ON and cmd:valve_OFF. The reason I use two records instead of one is simply because there are two buttons on the front panel of my control cubicle. And the PLC logic is that it checks whether only one button is pressed at a time. This is local control. Yet, at the same time I want to remotely control my system by means of EPICS.
Steve, do you recommend to change the SCAN field to passive?
Pavel
On Wed, Apr 4, 2012 at 6:12 PM, Tim Mooney <[email protected]> wrote:
Hi Pavel,
I don't understand.  Do you want the record automatically to switch its value back to 0 after somebody sets it to 1?  Do you want the switch back to happen after some time interval?  If so, the bo record's HIGH field might do what you want.
Tim
----- Original Message -----
To: "EPICS Tech Talk" <[email protected]>
Sent: Wednesday, April 4, 2012 8:42:40 AM
Subject: [db] simple command ?
Hello tech-talkers,
I would like to implement a simple command record, the idea of which is to switch its VAL to 1 and then back to 0. Let's assume we have got the following record:
record (bo,"cmd:valve_trigger")
field(PINI, "YES")
field(DTYP, "S7plc")
field(OUT, "@plc/0 T=UINT8 B=0")
field(SCAN, "I/O Intr")
field(ONAM, "ONE")
field(ZNAM, "ZERO")
Is there any straightforward solution?
Thank you.
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Best regards,
Pavel Maslov, MS
Re: [db] simple command ? Hartman, Steven M.
Re: [db] simple command ? Benjamin Franksen
[db] simple command ? Pavel Masloff
Re: [db] simple command ? Tim Mooney
Prev: Re: Doubt regarding Process Variable Kasemir, Kay
Next: Re: [db] simple command ? Hartman, Steven M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: [db] simple command ? Tim Mooney
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
