Hi:
Two issues.
1) CSS does not use those variables.
You need to check Edit/Preferences/CSS Core/EPICS
and edit them in there, or see
http://sourceforge.net/apps/trac/cs-studio/wiki/HierarchicalPreferences
about setting things like
org.csstudio.platform.libs.epics/auto_addr_list=false
org.csstudio.platform.libs.epics/use_pure_java=true
org.csstudio.platform.libs.epics/addr_list=127.0.0.1:12345
org.csstudio.platform.libs.epics/max_array_bytes=460000
The disadvantage:
Yes, it ignores those env. variables that we've grown
accustomed to.
The advantage:
You can see what it's actually using from Edit/Preferences/...
Compare that to figuring out what StripTool, Probe, EDM, .. are actually
using and which of /etc/bash_profile, ~/.bashrc, ... set it.
2) CSS currently uses CAJ 1.1.7, or a JNI version of JCA that
was build against EPICS base R3.14.11 or older for the Win32 binaries.
I don't think those support CA-over-ssh
-Kay
On 4/9/12 14:15 , "Peter Milne" <[email protected]> wrote:
>Currently using CSS on a remote session over the Net with NX, it's OK,
>but a local session would be better.
>CA tunnelled successfully over ssh:
>(IOC:5064 port forwarded to localhost:10013)
>export EPICS_CA_ADDR_LIST=localhost:10013
>export EPICS_CA_AUTO_ADDR_LIST=no
>export EPICS_CA_NAME_SERVERS=localhost:10013
>camonitor cpsc_011_UPTIME
>cpsc_011_UPTIME 2012-04-09 19:02:06.116235 107056
>cpsc_011_UPTIME 2012-04-09 19:02:07.116355 107057
>But on running css from the same shell session with the same exported
>variables, it's unable to see the PV
>=> Is it possible to view a tunneled PV from CSS?.
>Peter Milne [email protected]
>D-TACQ Solutions Ltd www.d-tacq.com
- does CSS (CAJ?) support CA over an ssh tunnel Peter Milne
Re: does CSS (CAJ?) support CA over an ssh tunnel Till Straumann
Re: does CSS (CAJ?) support CA over an ssh tunnel Andrew Johnson
<2012>
2025
<2012>
2025
