1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Stream Device parsing strings
To: [email protected]
Date: Wed, 11 Apr 2012 15:01:39 -0700
Hi all.
I am trying to get streamDevice to break an input string that has fields delimited with semi-colons into discrete strings. The input string as read by asyn + GPIB looks something like
BIN;RI;MSB;4;32;500;Y;100.00000000000E-12;20.90000000000E-9;"s";0.05000000000;5.00000000000E-9;21.00000000000E-9;0.00500000000;232.83064365387E-12;0.0000;"V";"C2, 50.00mV/div, 5.000ns/div,500 points, Sample mode";"C2"
My stream device protocol looks like:
WFMPRE {
    ReplyTimeout = 200;
    ReadTimeout = 50;
    InTerminator = LF;
    Separator = ";";
    out "VERBOSE ON";
    out "WFMO?";
    in "%(\$1PARAM01.VAL)s%(\$1PARAM02.VAL)s%(\$1PARAM03.VAL)s%(\$1PARAM04.VAL)s%(\$1PARAM05.VAL)s%(\$1PARAM06.VAL)s%(\$1PARAM07.VAL)s";
    out "VERBOSE OFF";
where the records referred to by $1PARAMxx.VAL are stringout records with SoftChannel DTYP. Each successive conversion ends at either the 39th converted character, or the first whitespace. It seems to be completely ignoring the specified separator. Is this correct behavior? If so, any suggestions for accomplishing what I want (ability to access the string fields as records or as string elements of a waveform record. I intend to add more field conversions to complete the string parsing, if/when I get this much working.
The data in question comes from a Tektronix scope, and contains the data need to convert a generically scaled waveform array into an array scaled to engineering units.
Thanks.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada.
Re: Stream Device parsing strings Ralph Lange
Prev: Re: DCT flag in record reference manual Andrew Johnson
Next: Re: Stream Device parsing strings Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: DCT flag in record reference manual Abadie Lana
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
