1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: log message filter in Asyn
To: <[email protected]>, <[email protected]>
Date: Wed, 18 Apr 2012 18:51:02 +0000
The problem is is that we already have loads of drivers issuing messages that they shouldn't do, so it would be good to have a solution that doesn't involve modifying these. True, lots of the messages should be only printed once. But there is a case for a driver repeating some kinds of message at some slow rate, to inform the terminal that 'something is still not right'. This gets round the problem of a single message being lost due to some other printout going on.
I think the linux kernel provides simple rate limiting on kernel printk messages, although I think that's more to do with dealing with the case where the developer isn't sure how frequently the message could be printed.
Cheers,
Matt
From: [email protected] [[email protected]] on behalf of Benjamin Franksen [[email protected]]
Sent: 18 April 2012 15:04
To: [email protected]
Subject: Re: log message filter in Asyn
On Wednesday, April 18, 2012, [email protected] wrote:
> > One simple idea would be to add a bit to the asynTrace flags,
> > ASYN_TRACE_NOREPEATS.  The asynTrace facility could remember the
> > previous error message for a particular pasynUser, and if the next one
> > is the same (except for the time stamp) then the message would not be
> > output.
> The drivers would then need to decide when to reset that flag, to print
> the message again. For example, if a comms error was resolved, but
> re-occurred again (say, an hour later). You would want a new message in
> that case.
> Seems like, in general, people wouldn't mind this functionality in the
> errlog layer. Perhaps as Nick suggested as a library that implemented
> the same interface, and was plugged in somehow. Or, could modify errlog
> by adding a function call in each function, that checks the message and
> rejects or accepts it.
Errlog is /not/ the right place to ensure error messages are issued in a
sensible way. Generic filtering of messages is too weak, it cannot know
which messages are important and which are not. It cannot decide which
errors are merely consequences of something at a lower level going wrong. It
is also very inefficient to filter messages that should not be issued in the
first place.
It is the driver that knows whether a port is disconnected. It can and
should report this exactly once. It can and should report, again only once,
when the port is connected again. Device support should /not/ issue an error
message if a lower level (i.e. driver) indicates that it already did so.
Note I am not talking about special debugging support. This is for normal
operation, where you do /not/ want log files to increase to Gigabytes in a
few days, simply because someone pulled a plug or forgot to switch on some
seldom looked at device after maintenance.
Cheers
Ben
Re: log message filter in Asyn Andrew Johnson
log message filter in Asyn matthew.pearson
RE: log message filter in Asyn Mark Rivers
RE: log message filter in Asyn matthew.pearson
Re: log message filter in Asyn Benjamin Franksen
Prev: Re: log message filter in Asyn Benjamin Franksen
Next: Re: log message filter in Asyn Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
