Subject: RE: Windows busy build error - epics 3.14.12.1
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Fri, 20 Apr 2012 10:43:03 +0000
Hi Emma,
The 5th choice: get the GraphicsMagick libraries that I've built with Visual Studio 2010 (spent days getting that to work a few months back). We use EPICS configured with static builds as Mark recommends -although some 3rd party support libraries only seem to work well as DLLs. It is perfectly possible to mix DLLs libraries with the static EPICS/IOC builds.
After working out the GraphicsMagick build the next issue was a similar one for the HDF5 libraries. I also now have MSVC 2010 builds of these.
We've been using Visual Studio 2010 on Windows 7 (actually Windows Server 2008R2) for a few months now. I'd really recommend staying with the more recent version of the Visual Studio as it is a rather painful task to upgrade when the tools become obsolete...
As I understand you have not currently got access to our svn repository I've tarred up our latest areaDetector release with our local DLS modifications (mainly the above mentioned libraries). I recommend that you copy the ADApp/hdf5Support/ and ADApp/magickSupport/ directories to your areaDetector build as it contains not just the MSVC2010 libs but also a few related minor tweaks to the Makefiles.
Please download the file from here: http://controls.diamond.ac.uk/downloads/other/files/areaDetector_1-7-1beta3-dls2.tar.gz
Just remember when you update to a new version of areaDetector (like 1-8) to not accidentally overwrite those MSVC2010 build libraries with Marks MSVC2008 build.
And of course let me know if you have trouble with it.
Cheers,
Ulrik
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Emma Shepherd
Sent: 20 April 2012 05:37
To: Mark Rivers; [email protected]
Aha - I see.  Thanks, will try to find a copy of VS 2008 in that case!
Emma
Sent: Friday, 20 April 2012 2:15 PM
To: Emma Shepherd; [email protected]
Hi Emma,
There is a 4'th choice as well:
- Use the prebuilt version of areaDetector for the windows-x64 platform.
If you want to build it yourself I would recommend just switching to VS 2008.
Sent: Thursday, April 19, 2012 10:54 PM
Hi Emma,
Unfortunately that problem is more difficult.
It is arising because the GraphicsMagick library supplied with areaDetector was built with Visual Studio 2008, and you are building with VS 2010.  Microsoft changed their C++ library in incompatible ways between those 2 releases.
You have 3 choices:
- Build GraphicsMagick yourself with Visual Studio 2010.
- Use Visual Studio 2008 instead of 2010
- Change the Makefiles and dbd files in areaDetector to eliminate the use of GraphicsMagick.  That will mean eliminating URLDriver and NDFileMagick.
Sent: Thursday, April 19, 2012 10:32 PM
Hi Mark,
Thanks for the reply.  Yes - I have defined ASYN in busy/configure/RELEASE.  I actually just came across your suggestion elsewhere (setting STATIC_BUILD=YES and SHARED_LIBRARIES=NO in base), and that does make the busy module build successfully.
I've run into the next problem now though!  Building AreaDetector 1-7 fails with a link error:
CORE_RL_Magick++_.lib(Color.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xran(void)" (?_Xran@_String_base@std@@SAXXZ)
CORE_RL_Magick++_.lib(Drawable.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xran(void)" (?_Xran@_String_base@std@@SAXXZ)
CORE_RL_Magick++_.lib(Blob.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xran(void)" (?_Xran@_String_base@std@@SAXXZ)
CORE_RL_Magick++_.lib(Image.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xran(void)" (?_Xran@_String_base@std@@SAXXZ)
CORE_RL_Magick++_.lib(Options.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xran(void)" (?_Xran@_String_base@std@@SAXXZ)
CORE_RL_Magick++_.lib(Exception.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xran(void)" (?_Xran@_String_base@std@@SAXXZ)
CORE_RL_Magick++_.lib(Geometry.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xran(void)" (?_Xran@_String_base@std@@SAXXZ)
CORE_RL_Magick++_.lib(Color.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xlen(void)" (?_Xlen@_String_base@std@@SAXXZ)
CORE_RL_Magick++_.lib(Drawable.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xlen(void)" (?_Xlen@_String_base@std@@SAXXZ)
CORE_RL_Magick++_.lib(Blob.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xlen(void)" (?_Xlen@_String_base@std@@SAXXZ)
CORE_RL_Magick++_.lib(Image.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xlen(void)" (?_Xlen@_String_base@std@@SAXXZ)
CORE_RL_Magick++_.lib(Options.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xlen(void)" (?_Xlen@_String_base@std@@SAXXZ)
CORE_RL_Magick++_.lib(Exception.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xlen(void)" (?_Xlen@_String_base@std@@SAXXZ)
CORE_RL_Magick++_.lib(Geometry.obj) : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xlen(void)" (?_Xlen@_String_base@std@@SAXXZ) simDetectorApp.exe : fatal error LNK1120: 2 unresolved externals
make[3]: *** [simDetectorApp.exe] Error 1120
make[3]: Leaving directory `C:/beamline/perforce/Dev/SBS/4_Controls/4_3_Network_Infrastructure/4_3_1_Comms_Common_Services/sw/epics/areaDetector-1-7/ADApp/simDetectorSrc/O.windows-x64'
make[2]: *** [install.windows-x64] Error 2
make[2]: Leaving directory `C:/beamline/perforce/Dev/SBS/4_Controls/4_3_Network_Infrastructure/4_3_1_Comms_Common_Services/sw/epics/areaDetector-1-7/ADApp/simDetectorSrc'
make[1]: *** [simDetectorSrc.install] Error 2
make[1]: Leaving directory `C:/beamline/perforce/Dev/SBS/4_Controls/4_3_Network_Infrastructure/4_3_1_Comms_Common_Services/sw/epics/areaDetector-1-7/ADApp'
make: *** [ADApp.install] Error 2
Hopefully just another simple configuration I'm missing?
Cheers,
Emma
Sent: Friday, 20 April 2012 12:47 PM
Hi Emma,
Have you defined ASYN in busy/configure/RELEASE?  It is optional, and the Makefile should work without it, but you need to define it if you plan to use busy with areaDetector.
It looks like you are building dynamically (i.e. building .dll files), because otherwise it would not need asyn when building the library, only when building an executable.
This should work, but it's possible there is a problem somewhere that has not been found, because most people build for Windows statically, not dynamically.
If you want to build areaDetector then I don't think you can build dynamically, some of the libraries supplied with areaDetector (e.g. GraphicsMagick) require a static build.
I suggest you change
EPICS_BASE/configure/os/CONFIG_SITE.windows-x64.windows-x64
to define
STATIC_BUILD=YES
SHARED_LIBRARIES=NO
You then need to rebuild base and synApps.
From: [email protected] [[email protected]] on behalf of Emma Shepherd [[email protected]]
Sent: Thursday, April 19, 2012 8:15 PM
To: [email protected]
Subject: Windows busy build error - epics 3.14.12.1
Hi folks,
Banging my head against a Windows build error...
I'm trying to get to the stage where I can build AreaDetector 1-7 on 64-bit Windows 7.  I can successfully build base-13-12-1 and asyn-4-18, but my first hurdle is that busy 1-4 fails with the following link error:
Creating library busy.lib and object busy.exp devBusyAsyn.obj : error LNK2001: unresolved external symbol pasynEpicsUtils devBusyAsyn.obj : error LNK2001: unresolved external symbol pasynInt32SyncIO devBusyAsyn.obj : error LNK2001: unresolved external symbol pasynManager devBusyAsyn.obj : error LNK2001: unresolved external symbol pasynTrace busy.dll : fatal error LNK1120: 4 unresolved externals
make[3]: *** [busy.dll] Error 1120
make[3]: Leaving directory `C:/beamline/perforce/Dev/SBS/4_Controls/4_3_Network_Infrastructure/4_3_1_Comms_Common_Services/sw/epics/busy-1-4/busyApp/src/O.windows-x64'
make[2]: Leaving directory `C:/beamline/perforce/Dev/SBS/4_Controls/4_3_Network_Infrastructure/4_3_1_Comms_Common_Services/sw/epics/busy-1-4/busyApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `C:/beamline/perforce/Dev/SBS/4_Controls/4_3_Network_Infrastructure/4_3_1_Comms_Common_Services/sw/epics/busy-1-4/busyApp'
make: *** [busyApp.install] Error 2
I'm using Visual Studio 2010, and gnumake.  The problem seems to be with the version of EPICS base, as I get the same problem when I try to compile it as 32-bit as well unless I revert to EPICS 3.14.11.  I can build other modules that depend on asyn just fine (like std).
Any ideas?
Emma
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Windows busy build error - epics 3.14.12.1 Emma Shepherd
RE: Windows busy build error - epics 3.14.12.1 Mark Rivers
RE: Windows busy build error - epics 3.14.12.1 Emma Shepherd
Prev: RE: Windows busy build error - epics 3.14.12.1 Emma Shepherd
Next: mrfioc2 compile error 송영기
Next: How to apply for Java SWT DateTime widget in CSS OPI? [SEC=UNCLASSIFIED] WANG, Jian
