1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: mrfioc2 compile error
To: 송영기 <[email protected]>
Cc: [email protected]
Date: Fri, 20 Apr 2012 15:48:34 +0100
On Fri, 2012-04-20 at 21:30 +0900, 송영기 wrote:
> Hi All,
> I am trying to compile the mrfioc2 drivers using the tutorial (Getting
> started with EPICS on RTEMS).
> The target board for the mrfioc2 is mvme3100.
> The tool source files and packages are as follows:
> binutils-2.19
> gcc-g++-4.3.2
> gcc-core-4.3.2  / gcc-core-4.3.2-rtems4.9-20081214.diff
> newlib-1.16.0 / newlib-1.16.0-rtems4.9-20090324.diff
> rtems-addon-packages-4.9.2
> rtems_libbspExt_1.5
> I successfully compiled gcc to cross-compile for powerpc-mvme3100 and
> created an example application with base-3.14.12.1.
> For compiling the mrfioc2, i added the location of external products
> including epics_base, devlib2 and autosave in
> mrfioc2/configure/RELEASE.
> When i tried to compile the mrfioc2, i get the error message as
> follows:
I had the same problem, and I think was the version of g++. I was using
4.1.2.
In devObjWf.cpp I replaced <epicsInt32[]> with <epicsInt32 *>,
<epicsInt8[]> with <epicsInt8 *> etc, and then it built correctly.
Paul.
RE: mrfioc2 compile error Davidsaver, Michael
mrfioc2 compile error 송영기
Prev: Re: mrfioc2 compile error Michael Davidsaver
Next: RE: mrfioc2 compile error Davidsaver, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
