Subject: Re: procServ softIOC server - V2.6.0 released
To: Ralph Lange <[email protected]>
Date: Mon, 23 Apr 2012 15:00:01 +0200
Ralph Lange wrote:
  On 16.04.2012 18:44, Pavel Masloff wrote:
Ralph, when I try to start a bat file using procServ under Windows 7 then I get this:
/C:\Users\Maslick\Downloads>procServ -L test2.txt 50010 c:\epics\apps\LINAC\startIoc.bat procServ: Error - Please change permissions on c:\epics\apps\LINAC\startIoc.bat to at least ---x--x--x
procServ is not able to continue without execute permission/
How can I set the bat file to be executable? Its attributes say it's Full access (R,W).
Pavel,
on native Windows file systems, Cygwin has to fake the permission info for files. So, obviously, the calls return no x bits for batch files. (Which makes sense, in a way.)
I am usually starting the softIOC binary directly, which does not create such a problem. If you need to use a batch file, you might have to start command.com (which is a real executable) with the batch file as first argument. You could also try specifying command.com as the executable using the command line option.
Good luck!
~Ralph
ps. Please drop me a line if you get it working, so I can add the solution to the README.
Ralph,
Maybe you could modify checkCommandFile() for Windows so that it either checks for executable extensions (.com, .bat, .exe, more?) or always returns 0. I mean, what can really go wrong if you don't check in advance?
Dirk
procServ softIOC server - V2.6.0 released Ralph Lange
Re: procServ softIOC server - V2.6.0 released Pavel Masloff
Re: procServ softIOC server - V2.6.0 released Ralph Lange
Prev: Re: RE: mrfioc2 compile error 송영기
Next: Control Engineer Job in SESAME ibrahim.saleh
Prev: Re: procServ softIOC server - V2.6.0 released Ralph Lange
Next: RE: procServ softIOC server - V2.6.0 released Mark Rivers
