Subject: mrfioc2 release 2.0.1
To: EPICS Tech-Talk <[email protected]>
Date: Mon, 23 Apr 2012 18:55:22 -0400
This release corrects a number of bugs including build issues with vxWorks. It also adds several minor features.
http://epics.sourceforge.net/mrfioc2/
Bug fixes
    * Fix several vxWorks build issues
* Correct initial mapping for EVR output channels to Force Low (aka. Off)
    * Fix readback of EVG sequencer run mode.
    * Limit number of soft event send retries
* More check for EVG and EVR during initialization. Should now catch old firmware versions and CSR address mapping problems.
    * Delay enabling VME interrupts for EVG until later during IOC startup.
    * Fix autosave/restore of CML output bit patterns.
* Remove rear transition module definitions from default EVG db template * Fix locking issue in data buffer tx/rx. A deadlock would occur when trying to send a buffer with the link mode set to dbus only.
Features
* Added evralias.db to facilitate creation of PV name aliases for EVR delay generator channels. * Always reset all EVG multiplexed counters when a divider value is changed.
    * Add counter to track number of times each EVG sequencer is run.
* Add mrmEvrForward() shell function to configure EVR event forwarding to downstream EVRs.
Prev: Control Engineer Job in SESAME ibrahim.saleh
Next: Re: RTEMS driver for SIS3820 scaler Kate Feng
Next: 6259 epics driver help ibadillo
