Subject: Re: labCa build fails on 64 bit Windows
Date: Thu, 03 May 2012 11:12:59 -0500
I built it on 64-bit windows7 for matlab 2011a. I don't recall what compiler version was used. Maybe Ernest can fill us in. He should also have access to the binaries;
if you're lucky they work for you.
- Till
On 05/03/2012 06:06 AM, [email protected] wrote:
Hi
Has anyone got labCa 3.4 to build on windows-64? If so, what combination of Matlab, Windows and Compiler are you using. I can't get it to work with Windows Server 2008, MatlabR2011b, Visual Studio 2010, EPICS 3.14.12.1
Initially the build fails building ezcaglue with some missing libraries:
link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref /release   /MACHINE:X64    c:/ma
tlab2011b/extern/lib/win64/microsoft/libut.lib c:/matlab2011b/extern/lib/win64/microsoft/libmx.lib c
:/matlab2011b/extern/lib/win64/microsoft/libmex.lib  /implib:mezcaglue.lib /out:mezcaglue.dll
    ini.obj multiEzca.obj ctrlC-polled.obj mglue.obj      ..\\..\\lib\\windows-x64\\ezcamt.lib  d:\ep
ics\r3.14.12.1\base\\lib\\windows-x64\\ca.lib  d:\epics\r3.14.12.1\base\\lib\\windows-x64\\Com.lib u
ser32.lib
    Creating library mezcaglue.lib and object mezcaglue.exp
ca.lib(ca_client_context.obj) : error LNK2001: unresolved external symbol __imp_bind
etc.
Adding ws2_32 and advapi32 to USR_SYS_LIBS fixes this but the mex functions fail:
make[2]: Entering directory `S:/Technical/Controls/Software/Matlab/Build/labca_3_4/matlab/O.windows-
x64'
c:/matlab2011b/bin/mex.bat   -DMATLAB_APP  ../lcaGetNelem.c -I. -I../O.Common -I. -I.. -I../../inclu
de/os/WIN32 -I../../include -Id:\epics\r3.14.12.1\base/include/os/WIN32 -Id:\epics\r3.14.12.1\base/i
nclude         -I../../ezca -I../../glue      ../../lib/windows-x64/mezcaglue.lib  ../../lib/windows
-x64/ezcamt.lib  d:\epics\r3.14.12.1\base/lib/windows-x64/ca.lib  d:\epics\r3.14.12.1\base/lib/windo
ws-x64/Com.lib  ../../lib/windows-x64/ezcamt.lib  d:\epics\r3.14.12.1\base/lib/windows-x64/ca.lib  d
:\epics\r3.14.12.1\base/lib/windows-x64/Com.lib ws2_32.lib advapi32.lib ws2_32.lib advapi32.lib user
32.lib kernel32.lib winmm.lib
    Creating library C:\Users\jr76\AppData\Local\Temp\3\mex_JqkfYu\templib.x and object C:\Users\jr76
\AppData\Local\Temp\3\mex_JqkfYu\templib.exp
lcaGetNelem.obj : error LNK2019: unresolved external symbol __imp_ezcaFree referenced in function me
xFunction
lcaGetNelem.mexw64 : fatal error LNK1120: 1 unresolved externals
   C:\MATLAB~1\BIN\MEX.PL: Error: Link of 'lcaGetNelem.mexw64' failed.
make[2]: *** [lcaGetNelem.mexw64] Error 2
make[2]: Leaving directory `S:/Technical/Controls/Software/Matlab/Build/labca_3_4/matlab/O.windows-x
64'
make[1]: *** [install.windows-x64] Error 2
make[1]: Leaving directory `S:/Technical/Controls/Software/Matlab/Build/labca_3_4/matlab'
make: *** [matlab.install] Error 2
S:\Technical\Controls\Software\Matlab\Build\labca_3_4>
James
Re: labCa build fails on 64 bit Windows Ernest L. Williams Jr.
labCa build fails on 64 bit Windows james.rowland
Prev: RE: CA_PROTO_READ_NOTIFY Response graham.cox
Next: Re: [Scopes] BMP image record?? Pavel Masloff
Prev: labCa build fails on 64 bit Windows james.rowland
Next: Re: labCa build fails on 64 bit Windows Ernest L. Williams Jr.
