Subject: Re: [Scopes] BMP image record??
To: Pavel Masloff <[email protected]>
Date: Fri, 4 May 2012 18:18:34 -0700
On May 4, 2012, at 6:11 PM, Pavel Masloff wrote:
> Thanks Mark,
> When I save the waveforms manually on the CF card each csv file is precisely 73,5 Kb.
That's because it's storing the values as ASCII numbers.
The waveform data transfer can take place in raw binary format using one byte per point per trace as Mark pointed out.
So transferring all 2500 points from all four traces would still be only 10,000 bytes.
Eric Norum
[email protected]
Re: [Scopes] BMP image record?? Pavel Masloff
Re: [Scopes] BMP image record?? Dirk Zimoch
RE: [Scopes] BMP image record?? Mark Rivers
Re: [Scopes] BMP image record?? Rod Nussbaumer
Prev: Re: [Scopes] BMP image record?? Pavel Masloff
Next: Re: [Scopes] BMP image record?? Pavel Masloff
