1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: undefined symbol:MAXvSetup
To: <[email protected]>
Date: Sun, 6 May 2012 15:59:51 +0800
Hello
Thank you very much for your reply.
I have added extern "C" before the function definition of MAXvSetup() and RTN_VALUES MAXvConfig(), but unfortunately, this can not solve my problem, and when I download st.cmd to the VME crate, it is still display the error: “undefined symbolMAXvSetup”.
And I change the order of libs in makefile, it can not solve the problem also.
When I input nm command(nm bisaxsioc.munch | grep MAXvSetup) in the /bin/ vxWorks-ppc604_long directory, it displays nothing. So I think the .munch file does not correctly define the symbol MAXvSetup. Now I do not know what is the reason.
And I have another question, I have seen some OmsSrc/Makefile in some worked program, a part of the source code is bisaxs_SRCS_vxWorks += devMAXv.cc drvMAXv.cc, but the source file of OmsSrc which I copied from synApps_5_3/support/motor/6-3/motorApp/OmsSrc is SRCS += devMAXv.cc drvMAXv.cc. so I do not know if I should change it into the word of omsMAXv_SRCS_vxWorks.
Thank you very much.
hongchunxia
No.239 Zhangheng Road
PuDong District
Shanghai Institute of Applied Physics CAS
Shanghai, China
RE: undefined symbol:MAXvSetup Mark Rivers
Prev: Control Engineer Job in SESAME ibrahim.saleh
Next: RE: undefined symbol:MAXvSetup Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: undefined symbol:MAXvSetup Mark Rivers
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
