Subject: Re: EPICS3.14.12 RTEMS patch for nfsMount() ( was Re: Autosave and RTEMS-4.10)
To: Kate Feng <[email protected]>
Cc: [email protected]
Date: Wed, 16 May 2012 12:28:39 -0500
Hi Kate,
On 2012-05-15 you wrote:
> It seems like an oversight that nfsMount() command was declared static
> in rtems_init.c().
> The patch below for EPICS3.14.12.x would simply solve the error of
> "undefined reference to `nfsMount' ". This should be fixed in R3.14.12.2
> and higher version too.
I have committed this change to the R3.14 branch (so it will appear in
R3.14.12.3), and added a patch file to the Known Problems page for R3.14.12.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Autosave and RTEMS-4.10 송영기
Re: Autosave and RTEMS-4.10 Kate Feng
EPICS3.14.12 RTEMS patch for nfsMount() ( was Re: Autosave and RTEMS-4.10) Kate Feng
Prev: Re: 回复: RE: Problem in using synApp Tim Mooney
Next: Re: 回复: RE: Problem in using synApp Tim Mooney
Prev: EPICS3.14.12 RTEMS patch for nfsMount() ( was Re: Autosave and RTEMS-4.10) Kate Feng
Next: [StreamDevice] need advice Pavel Masloff
