1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: stream device driver parse question
To: [email protected]
Date: 17 May 2012 10:14:43 +0200
you can use the redirection mechanism of streamdevice.
Just configure your ai1 record to use stream as DTYP and the protocol as input:
record (ai "ai1") {
    field (DTYP, "stream")
    field (INP,  "@myDev.proto getMsg dev1")
    field (SCAN, "I/O Intr")
Your protocol would look like this:
getMsg {
  in "*05CC%d#*05DD%(ai2.VAL)d#*05EE%(ai3.VAL)#"
I'm not sure though if one should define the length for the format converters here?
Best regards,
Florian
Am 17.05.2012 07:15, schrieb Silver:
hi, all:
   If the device send a string to IOC automaticlly, the data is like "*05CC1234#*05DD5678#*05EE1345#". I have three ai records as ai1,ai2,ai3.
I want to get "1234" of "*05CC1234#" to ai1, "5678" of "*05DD5678#" to ai2, "1345" of "*05EE1345#" to ai3, how can I implement it?
   thanks a lot in advance.
Best regards
Geyang  2012-05-17
Re: stream device driver parse question Dirk Zimoch
stream device driver parse question Silver
Prev: stream device driver parse question Silver
Next: LivEPICS 2012 released Jack
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: stream device driver parse question Dirk Zimoch
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
