1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: CSS build with Eclipse RCP-3.7 and -pluginCustomization
To: <[email protected]>
Date: Fri, 18 May 2012 14:28:40 +1000
We are building our own CSS product with RCP-3.7. And I found the -pluginCustomization option does not work any more. I debugged the program a bit more and found the following source code:
org.eclipse.equinox.internal.app.CommandLineArgs (org.eclipse.equinox.app.source_1.3.100.v20110321.jar)
<pre>
// obsolete command line args
private static final String NO_PACKAGE_PREFIXES = "-noPackagePrefixes"; //$NON-NLS-1$
private static final String NO_UPDATE = "-noUpdate"; //$NON-NLS-1$
private static final String BOOT = "-boot"; //$NON-NLS-1$
private static final String CLASSLOADER_PROPERTIES = "-classloaderProperties"; //$NON-NLS-1$
private static final String PLUGINS = "-plugins"; //$NON-NLS-1$
private static final String FIRST_USE = "-firstUse"; //$NON-NLS-1$
private static final String NEW_UPDATES = "-newUpdates"; //$NON-NLS-1$
private static final String UPDATE = "-update"; //$NON-NLS-1$
private static final String PASSWORD = "-password"; //$NON-NLS-1$
private static final String KEYRING = "-keyring"; //$NON-NLS-1$
private static final String PLUGIN_CUSTOMIZATION = "-pluginCustomization"; //$NON-NLS-1$
</pre>
So it seems -pluginCustomization is obsolete. But I can't find what I should use instead. Am I missing something? Has anyone else encountered this problem?
Thanks
Xinyu WU
ASKAP Computing
Australia Telescope National Facility
CSIRO Astronomy and Space Science
phone: +61 2 9372 4727
postal: PO Box 76 Epping, NSW. 1710
Re: CSS build with Eclipse RCP-3.7 and -pluginCustomization Kasemir, Kay
Prev: Re: stream device driver parse question Rod Nussbaumer
Next: Re: cPCI express Urša Rojec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: [EDM] on windows? Steiner, Mathias
Next: Re: CSS build with Eclipse RCP-3.7 and -pluginCustomization Kasemir, Kay
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
