1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: CSS BOY EDL --> OPI
To: Pavel Masloff <[email protected]>, "[email protected]" <[email protected]>
Cc: "Chen, Xihui" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 23 May 2012 09:40:31 -0400
Hello:
The EDL to OPI converter is very simplistic.
It only converts labels, textupdates and rectangles.
We started the framework for the converter, but very few widgets and properties are actually converted.
At the SNS, we currently have no urgent need to invest time into this.
It's also quite unclear how to convert many details.
We have tons of EDM screens where "rectangles" are placed around a bunch of widgets with a Label on top.
Those should really be converted into a Grouping Container:
It marks the meaning of that line around stuff, it allows move, resize, other edit operations on the group.
We also have quite a few EDM screens with invisible buttons behind rectangles with conditional visibility, talking to local PVs that control the content of embedded windows.
Those should really be converted into a Tab Container, because again that's what you wanted to create in the first place.
There are more examples for EDM display files being a bit like compiled code, and it's hard for an automated tool to reconstruct what was originally meant:
Circle that happens to change color, or 'LED' - type indicator?
Nevertheless, if there is a site with some programming resources who has a need to convert EDM screens and wants to work on this, we're happy to guide you through the existing converter framework so that you can add the code for more widgets and their properties.
Kay
From: Pavel Masloff <[email protected]<mailto:[email protected]>>
To: "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>>
Cc: "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>>
I have had some problems with converting EDLs to OPI as well (CSS 3.0.1).
I get no error messages, however. When I open the resulting opi file, it contains merely 5% of the original edl file.
May I ask anyone to convert a sample edl file for me (which I will send to them later) and confirm/disprove my assumptions?
Thanks in advance.
On Wed, May 23, 2012 at 12:11 PM, <[email protected]<mailto:[email protected]>> wrote:
Hello,
I am using CSS BOY (Css 3.1.0.20120201 org.csstudio.basic.epics.product.product) for the first time with some success.
However I have had no luck with converting EDL to OPI.
Pasted below is the error I am getting. Is there any way to get a more detailed problem description?
  giles...
2012-05-23 09:08:11.529 WARNING [Thread 13] org.csstudio.opibuilder.converter.ui.ConvertToOPIAction (convertFile) - Conversion error in file L/Motor/motor-readback.edl
org.csstudio.opibuilder.converter.model.EdmException: SPECIFIC_PARSING_ERROR exception: Error when parsing annotated field.
       at org.csstudio.opibuilder.converter.model.EdmEntity.<init>(Unknown Source)
       at org.csstudio.opibuilder.converter.model.EdmDisplay.<init>(Unknown Source)
       at org.csstudio.opibuilder.converter.model.EdmModel.getDisplay(Unknown Source)
       at org.csstudio.opibuilder.converter.writer.OpiWriter.writeDisplayFile(Unknown Source)
       at org.csstudio.opibuilder.converter.ui.ConvertToOPIAction.convertFile(Unknown Source)
       at org.csstudio.opibuilder.converter.ui.ConvertToOPIAction.access$1(Unknown Source)
       at org.csstudio.opibuilder.converter.ui.ConvertToOPIAction$1.run(Unknown Source)
       at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Re: CSS BOY EDL --> OPI Pavel Masloff
Prev: Re: CSS BOY EDL --> OPI Pavel Masloff
Next: Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Allen-Bradley Ethernet/IP driver and CompactLogix PLC's Elliott Wolin
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
