Subject: Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater
To: "Ernest L. Williams Jr." <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Wed, 23 May 2012 07:56:41 -0700
Ernest:
It sounds like your question is the same as one I posed earlier, and Andrew's reply may be helpful:
<http://www.aps.anl.gov/epics/tech-talk/2010/msg00978.php>
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
Ernest L. Williams Jr. wrote:
I found that I need to have caRepeater available for my target but EPICS
BASE does not build it.
How have others done this?
We build our target as a CROSS, so caRepeater only gets built for HOST
builds.
Now for vxWorks and RTEMS, they use "repeater.cpp" which gets linked in.
What I have done for our embedded linux target is the following, is this
acceptable?
Modify, <BASE>/src/ca/Makefile
And added:
ifeq ($(T_A),linuxRT-x86)
  PROD_DEFAULT += caRepeater catime acctst caConnTest casw caEventRate
endif
Then, I did a build like so,
make CROSS_COMPILER_TARGET_ARCHS=linuxRT-x86
Thanks in advance for your comments and help.
Cheers,
Ernest
Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater Ernest L. Williams Jr.
Prev: Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater Michael Davidsaver
Next: Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater Ernest L. Williams Jr.
Prev: Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater Ernest L. Williams Jr.
