Subject: RE: medm and Xming on Windows 7 64 bit
To: "'Troy Lutes'" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 24 May 2012 17:37:39 +0000
Hi Troy,
I am quite sure I ran into that same problem on a Windows 7 32-bit system recently.
I worked around the problem by not installing the 2011 1.42 or 1.41 builds of the EPICS Windows Tools, but rather installing the 1.40 build from 2007.  I did not take much time to investigate, but I'm quite sure that worked.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Troy Lutes
Sent: Wednesday, May 23, 2012 3:04 PM
To: [email protected]
Subject: medm and Xming on Windows 7 64 bit
We are setting up an IOC for HPSync. The IOC seems to startup fine, but there are problems with the display. We have installed Xming as described in:
http://controls.web.psi.ch/cgi-bin/twiki/view/Main/HowToSetupEPICSWin32
Probe, alarm handler, strip tool, etc all work fine from the icons in the win32 tools folder.
Medm gives the following error in the Xconsole
[medm]
MEDM Version 3.1.5: Loading aliased fonts.................
SIGSEGV
Does anybody have experience with Xming and medm?
Thanks in advance,
Troy
Troy Lutes
Linux Systems Administrator
Advanced Photon Source
Argonne National Laboratory
(630)252-1345
Re: medm and Xming on Windows 7 64 bit Pavel Masloff
medm and Xming on Windows 7 64 bit Troy Lutes
Prev: Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Eric Norum
Next: Re: medm and Xming on Windows 7 64 bit Pavel Masloff
Prev: Re: medm and Xming on Windows 7 64 bit Paul Sichta
