Subject: [StreamDevice] parsing rapid inputs
To: Dirk Zimoch <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 30 May 2012 12:15:27 +0400
Hello,
I have run into a problem lately. I have sort of a slow device - a TDS2024 scope. So when I run my IOC, I expect StreamDevice to initialize my PVs. So there are ~ 20 PVs I want to initialize. And every once in a while I get the following error message in epics shell:
2012/05/30 13:02:25.211 L2 TDS2024:probe_ch2: got "<0d>:CH2:PROBE 1" where ":CH2:PROBE " was expected
This <0d> character (or CR) is driving me mad. This is because it was supposed to be the terminator of the previous input (here is the whole string together with the one above):
2012/05/30 13:02:25.124 /dev/ttyUSB0 read 13
:CH1:PROBE 1\n
As you can see, there is an \r missing. So my <0d> comes as a part of the input ":CH2:PROBE 1" - so I get "<0d>:CH2:PROBE 1"  instead which causes the error.
How can I fix this?
I have tried using the @mismatch handler, but it doesn't work within the @init handler.
And you will never know which PV will not initialize next.
As an comparison, my TPS2024 and TPS2024B scopes are fast enough to stumble upon this. No problem there.
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Land line: +7 (812) 461 01 01
RE: [StreamDevice] parsing rapid inputs Mark Rivers
Re: [StreamDevice] parsing rapid inputs Dirk Zimoch
Prev: RE: device support for CPCI michael.abbott
Next: RE: device support for CPCI mark.heron
Prev: Re: device support for CPCI Julio Calvo
Next: RE: [StreamDevice] parsing rapid inputs Mark Rivers
