1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: calc VAL field not updating from bi VAL field
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Wed, 30 May 2012 13:06:46 -0500
On 5/30/12 12:25 PM, Tim Mooney wrote:
> It seems that the integer to double conversion really is not exact for 1.  If so, it wouldn't be exact for either 1.
> Could you try "nint(a)=nint(1)?1:0"
Hi, Tim.
No dice--that does not work.
Lewis
Re: calc VAL field not updating from bi VAL field Tim Mooney
Prev: ether_ip problem reading DINT arrays Bob Gunion
Next: RE: ether_ip problem reading DINT arrays Dudley, David
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: calc VAL field not updating from bi VAL field Tim Mooney
Next: Re: calc VAL field not updating from bi VAL field Eric Norum
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
