Subject: Re: Proposed change in asyn - request for comments
Cc: EPICS Techtalk <[email protected]>
Date: Wed, 30 May 2012 11:33:58 -0700
When you say, "have the TSE be accurate", do you mean "have the time (obtained from the event system and corresponding to the most recent arrival of the event whose number is in the record TSE field) be accurate"?
The TSE field doesn't hold a time value -- it merely specifies the source from which a time value is to be obtained.
On May 30, 2012, at 10:23 AM, Mark Rivers wrote:
> I'm not sure I understand this.  I am supposing that the areaDetector acquisition can keep up, but that there is a pipeline delay.  If the image frames are tagged at the moment they are acquired the TSE should be valid, even though by the time the records process it may not be the same pulse.  Wouldn't it be useful to have the TSE be accurate for such PVs even if they don't finish processing until 1 or more events later?
> Mark
Eric Norum
[email protected]
Proposed change in asyn - request for comments Mark Rivers
Re: Proposed change in asyn - request for comments Ernest L. Williams Jr.
Re: Proposed change in asyn - request for comments Eric Norum
RE: Proposed change in asyn - request for comments Mark Rivers
RE: Proposed change in asyn - request for comments Allison, Stephanie
Prev: RE: ether_ip problem reading DINT arrays Dudley, David
Next: Re: calc VAL field not updating from bi VAL field Eric Norum
Prev: RE: Proposed change in asyn - request for comments Mark Rivers
Next: RE: Proposed change in asyn - request for comments Allison, Stephanie
