Subject: Re: ether_ip problem reading DINT arrays
To: [email protected]
Date: Wed, 30 May 2012 13:26:38 -0700
Ah, so I'm not crazy after all..  Thanks David - I've reverted to 2.19 and will eagerly await your update.
Bob
On May 30, 2012, at 11:30 AM, Dudley, David wrote:
> This is related to another bug I'm fixing right now.
> Should have a fix soon (within a day or two), along with enhancements and corrections to the MBBI, MBBO, MBBIDirect, and MBBODirect records.
> If you're not reading any discrete BOOLs from the PLC, you can immediately revert to ether-ip-2.19 which was before the bug was introduced, but that package won't read discrete BOOLs unless they are in a Boolean array.
> David
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Bob Gunion
> Sent: Wednesday, May 30, 2012 1:55 PM
> Subject: ether_ip problem reading DINT arrays
> I am writing a soft ioc to talk with an Allen-Bradley CompactLogix L33ER PLC.  Everything works fine except I cannot read elements of a DINT array.  I have a tag is defined in the PLC as "DINTs" with a type like DINT[4], and records like:
> record(ai, "TEST_DINT0")
> 	field(SCAN, ".1 second")
> 	field(DTYP, "EtherIP")
> 	field(INP, "@plc DINTs[0]")
> record(ai, "TEST_DINT1")
> 	field(INP, "@plc DINTs[1]")
> record(ai, "TEST_DINT2")
> 	field(INP, "@plc DINTs[2]")
> record(ai, "TEST_DINT3")
> 	field(INP, "@plc DINTs[3]")
> By cranking up the debugging output I can see the proper values being read by the scanner, but they never make it into the RVAL field of the pvs.  If I specify four separate tags (DINT0, DINT1, etc), the values do make it into the pvs.  So there's a problem with specifying the array element.
> Digging through the code, I have found that the analyze_link function in devEtherIP.c detects the element index specification and, on line 899, sets pvt->special |= SPCO_INDEX_INCLUDED.  In ai_read (line 1139 of the same file), the tag value is retrieved into the pv only if pvt->special < SPCO_PLC_ERRORS; otherwise the record is marked as UDF.  This looks like a bug, unless I'm doing something wrong.
> Is anyone else using this package to read arrays of DINTs (or REALs, etc)?  Am I missing something?
> Thanks,
> Bob Gunion
ether_ip problem reading DINT arrays Bob Gunion
RE: ether_ip problem reading DINT arrays Dudley, David
Prev: Re: calc VAL field not updating from bi VAL field J. Lewis Muir
Next: Re: Proposed change in asyn - request for comments Bruce Hill
Prev: RE: ether_ip problem reading DINT arrays Dudley, David
Next: errro running "ibtest" tzk6s
