1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: asynManager isConnected
To: <[email protected]>
Date: Fri, 1 Jun 2012 11:17:09 +0000
I'm trying to use asynManager isConnected() to test whether or not an IP port is connected to a device. But I'm finding that isConnected() only seems to report the connected status of the asynUser structure to the underlying device.
If I attempt to call drvAsynIPPort on an IP address that has nothing connected to it, the connection fails. Then I attempt to connect an asynUser to this port using asynOctetSyncIO connect(), which also fails. Then I call asynManager isConnected a few times, and I find that the first few calls return false, and then after iocInit it returns true. But still, in the background, asynManager is attempting to connect to the IP port via the autoConnect feature.
Is this behaviour correct?
I can get around it by maintaining connected status myself. But the documentation seems to indicate that isConnected() shouldn't return true if the IP port is not connected.
Also, if I call asynOctetSyncIO writeRead, with a 5s timeout, I find it blocks forever if the IP port is not connected.
Any ideas?
Cheers,
Matt
RE: asynManager isConnected Mark Rivers
Re: asynManager isConnected J. Lewis Muir
Prev: Re: waveform of STRING memory structure Pavel Masloff
Next: mbbi/mbbo Mask values Dudley, David
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: asynManager isConnected Mark Rivers
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
