Subject: Re: mbbi/mbbo Mask values
To: "Dalesio, Leo" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 1 Jun 2012 12:42:53 +0000
I am assuming that is defined somewhere?
Looking at the MBBI record definition, I see that Mask, ZRVl, ONVL, … FFVL are all ULONGS, which would allow a bit field to be defined that didn't depend on consecutive bits.  Seems that the limitation is that NOBT defines MASK.
If NOBT was set to 0 (I would take that meaning as "don't define mask"), seems MASK 'should' be able to be manipulated.
Looking in the ether-ip driver, it doesn't look like mask from the record is even used.  It builds it's own internally.
David
Date: Friday, June 1, 2012 8:34 AM
To: David Dudley <[email protected]>, "[email protected]" <[email protected]>
Subject: RE: mbbi/mbbo Mask values
The limit/definition of the MBBx record types was that the bits were consecutive.
I think that you would have to use a calc record between the input and MBBx record to mask out the bits in between.
Bob
RE: mbbi/mbbo Mask values Dalesio, Leo
Prev: RE: mbbi/mbbo Mask values Dalesio, Leo
Next: RE: mbbi/mbbo Mask values Dalesio, Leo
