Subject: Re: mbbi/mbbo Mask values
To: EPICS Tech Talk <[email protected]>
Date: Sun, 03 Jun 2012 20:07:36 +0200
On Fri Jun 01 2012 19:54:15 GMT+0200 (CEST), Andrew Johnson
<[email protected]> wrote:
> MASK is currently marked as special(SPC_NOMOD) which means it can't be changed
> at run-time.  I don't like fields that can be set in a database file but not
> changed afterwards, so I think this needs a little more thought before opening
> MASK up to the world.
I wouldn't have much of a problem with this.
It is part of the configuration for device/driver support, and - with
the notable exception of device support that uses the extended DSET - V3
device support usually does not allow. i.e. ignores configuration
changes at run time.
The similar fields SHFT, NOBT, and OUT/INP can also be changed at
run-time, so making MASK one more with that semantics seems ok to me.
~Ralph
RE: mbbi/mbbo Mask values Dalesio, Leo
Re: mbbi/mbbo Mask values Andrew Johnson
Prev: RE: asynManager isConnected Mark Rivers
Next: [StreamDevice] ? Pavel Masloff
Prev: Re: mbbi/mbbo Mask values Andrew Johnson
Next: adding a prefix to all PV names with macro substitution Martin Konrad
