Subject: Re: [StreamDevice] ?
Date: Mon, 4 Jun 2012 17:06:24 +0400
Hey Mark!
Do you mean I should uncomment this line:  in "CH\$1:SCA?"; ?
setY {
    ReplyTimeout = 5000;
    out 'CH\$1:SCA %g';
    in "CH\$1:SCA?";
    @init {
            out "CH\$1:SCA?";
        in ":CH\$1:SCALE %g";
This won't work because when the probe_ch1 is processed it causes CHx_Voltage ($(P)$(R)setY1) to process, the latter will send the command to set the current vertical resolution - so it will first set the current value, then will read the current value, not the new value. You see - I have to either use open_loop or closed_loop, not both at the same time. Or I could add another readback record, but this will mess up the HMI with another widget.
On Mon, Jun 4, 2012 at 3:31 PM, Mark Rivers <[email protected]> wrote:
I would suggest having  CHx_Voltage read the current vertical resolution.  Leave this record Passive.  But have the  probe_ch1 record's FLNK be CHx_Voltage, so it reads the vertical scale once each time you change the probe attenuator.
From: [email protected] [[email protected]] on behalf of Pavel Masloff [[email protected]]
Sent: Monday, June 04, 2012 3:23 AM
To: Rod Nussbaumer; EPICS Tech Talk
Subject: [StreamDevice] ?
Hi Rod,
You mentioned you are using StreamDevice to talk to your Tek scopes. I am having difficulties with the Probe Attenuator setting. So you basically change it say from 1 to 10, and the scope automatically changes the voltage on a channel from say 1V to 10V/DIV.
I don't want StreamDevice to poll the scope once a second (or even worse I/O interrupt) to get this change (wanna leave it Passive), so I can change my Attenuator PV (Passive record) it then forwards the CHx_Voltage to ask the scope the current Y-axis resolution.
The problem is that the AO record can be either closed-loop (via db links) or open-loop (via CA).
I don't know what to do.
In other words:
On the screenshot is my HMI (http://imageshack.us/photo/my-images/337/scope.jpg/). So when I change the Attenuator_1 setting (probe_ch1) from 1 to 10, my CH_1 voltage (setY1) remains the same = 0,2 V, when in fact on the scope it is 2 V. Is there a way my setY1 could update its value, but not process?
record(ao, "$(P)$(R)setY1")
   field(DESC, "Set VOLTS/DIV channel 1")
   field(DTYP, "stream")
   field(OUT,  "@devTPS20xx.proto setY(1) $(PORT) $(A)")
   field(EGU, "V")
record(ao, "$(P)$(R)probe_ch1") {
 field(DESC, "Probe voltage attenuation 1")
 field(OUT, "@devTPS20xx.proto probe(1) $(PORT) $(A)")
setY {
    out 'CH\$1:SCA %g';
   #in "CH\$1:SCA?";
   @init {
           out "CH\$1:SCA?";
probe {
   out 'CH\$1:PRO %g';
   @init {
           out 'CH\$1:PRO?';
       in ':CH\$1:PROBE %g';
#getY {
#    out 'CH\$1:SCA?';
#    in "%g";
Hope everything is understandable.
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
[StreamDevice] ? Pavel Masloff
RE: [StreamDevice] ? Mark Rivers
Prev: RE: [StreamDevice] ? Mark Rivers
Next: Quiz for C experts Andrew Johnson
Next: Re: [StreamDevice] ? Pavel Masloff
