Subject: Re: Runaway connection count on IOC
To: [email protected]
Date: Mon, 11 Jun 2012 09:59:13 -0500
Hi again,
Earlier I wrote:
> Your 'casr 2' is being run at a much higher priority than the other Channel
> Access activities.  I suspect your CPU is too busy handling higher priority
> operations to spend any time actually running the low-level CA threads that
> communicate with client.
To finish my theory of what's happening here...
When 'casr 2' is run from the shell it goes through each of the client
connections in turn and takes a mutex for the channel.  If the mutex is
already owned by a thread that is otherwise CPU-starved, the act of taking the
mutex triggers the vxWorks thread priority inversion protection and raises the
priority of the thread that owns the mutex up to the shell's priority.  This
gives it a chance to actually run and complete what it was trying to do.
That's why I think your 'casr 2' causes the duplicate circuits to get cleaned
up properly.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Runaway connection count on IOC michael.abbott
Re: Runaway connection count on IOC Andrew Johnson
Prev: Re: Runaway connection count on IOC Andrew Johnson
Next: RE: Runaway connection count on IOC Hill, Jeff
Next: RE: Runaway connection count on IOC -- Possible Gateway Issue? michael.abbott
